Debian/Ubuntu automatic HTTPS configuration
danger
If you are changing your domain from HTTP to HTTPS, you will unlink all users' browser extensions. Before making this change, you must ensure that all users have a copy of their private key to recover their account.
Pro tip: To download their recovery kit, users can follow this dedicated guide
important
This configuration does not support running passbolt from a subdirectory like https://mydomain.com/passbolt. It is only designed to work with a Fully Qualified Domain Name (FQDN), either on the root domain https://mydomain.com or a subdomain https://passbolt.mydomain.com.
The ACME challenge requires port 80 to be open and accessible from the internet. Some administrators disable HTTP traffic on port 80 for security reasons, but this will prevent TLS (SSL) certificate generation and renewal. Ensure port 80 is open in your firewall and not blocked by your hosting provider.
Install or reconfigure passbolt
If you don’t have passbolt installed please check on the hosting section for more information on how to install passbolt on debian.
If you have already installed passbolt then you want to execute the following command to start the configuration process for TLS (SSL):
sudo dpkg-reconfigure passbolt-pro-server
You most likely want to say ‘NO’ to the mariadb/mysql setup question and go for the nginx setup
The passbolt debian based package currently supports the configuration of nginx. It comes with a default configuration that supports:
  • Serving passbolt on port 80 (http)
  • Serving passbolt on port 443 (https)
The following steps will guide you through the option that uses Let’s encrypt method to enable SSL.
Configure nginx dialog
fig. Configure nginx dialog
After choosing yes you will be prompted with the following dialog where you can choose which method you prefer to configure SSL on nginx:
nginx SSL dialog
fig. nginx SSL dialog
You will now need to introduce the name of the domain name assinged to your server:
nginx domain name
fig. nginx domain name
Finally you will need to provide an email address for Let’s encrypt to notify you for renewals and other admin info:
lets encrypt admin email
fig. lets encrypt admin email
If everything goes fine you should see a final message that points you to finish passbolt configuration:
Success message
fig. Success message
sudo systemctl reload nginx
Finally, ensure fullBaseUrl value in /etc/passbolt/passbolt.php starts with https://.
