Docker automatic HTTPS configuration
If you are changing your domain from HTTP to HTTPS, you will unlink all users' browser extensions. Before making this change, you must ensure that all users have a copy of their private key to recover their account.
Pro tip: To download their recovery kit, users can follow this dedicated guide
The ACME challenge requires port 80 to be open and accessible from the internet. Some administrators disable HTTP traffic on port 80 for security reasons, but this will prevent TLS (SSL) certificate generation and renewal. Ensure port 80 is open in your firewall and not blocked by your hosting provider.
Requirements
- docker setup with docker compose.
- A domain name reachable over the internet
Add traefik service to handle https
If you have followed our installation documentation, you should have defined db and passbolt services for your passbolt stack.
To handle HTTPS setup with Let’s Encrypt, add a traefik service as follow:
version: '3.7'
db:
traefik:
image: traefik:2.6
restart: always
- 80:80
- 443:443
- ./conf/:/etc/traefik/conf
- ./shared/:/shared
Traefik will:
- act as a proxy in front of passbolt service, that’s why we defined ports 80 and 443.
- handle Let’s Encrypt certificates renew.
Configuration files
Create a traefik.yaml configuration file with this content (replace [email protected] with your email for Let’s Encrypt):
global:
sendAnonymousUsage: false
log:
level: INFO
format: common
providers:
docker:
endpoint: 'unix:///var/run/docker.sock'
watch: true
exposedByDefault: true
swarmMode: false
file:
directory: /etc/traefik/conf/
watch: true
api:
dashboard: false
debug: false
insecure: false
entryPoints:
web:
address: ':80'
http:
redirections:
entryPoint:
to: websecure
scheme: https
permanent: true
websecure:
address: ':443'
certificatesResolvers:
letsencrypt:
acme:
email: [email protected]
storage: /shared/acme.json
caServer: 'https://acme-v02.api.letsencrypt.org/directory'
keyType: EC256
httpChallenge:
entryPoint: web
tlsChallenge: {}
Create a conf folder:
mkdir conf
In the conf folder, create 2 files:
conf/headers.yaml:
http:
middlewares:
SslHeader:
headers:
FrameDeny: true
AccessControlAllowMethods: 'GET,OPTIONS,PUT'
AccessControlAllowOriginList:
- origin-list-or-null
AccessControlMaxAge: 100
AddVaryHeader: true
BrowserXssFilter: true
ContentTypeNosniff: true
ForceSTSHeader: true
STSIncludeSubdomains: true
STSPreload: true
ContentSecurityPolicy: default-src 'self' 'unsafe-inline'
CustomFrameOptionsValue: SAMEORIGIN
ReferrerPolicy: same-origin
PermissionsPolicy: vibrate 'self'
STSSeconds: 315360000
conf/tls.yaml:
tls:
options:
default:
minVersion: VersionTLS12
sniStrict: true
curvePreferences:
- CurveP521
- CurveP384
cipherSuites:
- TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
- TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384
- TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256
traefik.yaml, conf/headers.yaml and conf/tls.yaml will be mounted inside traefik container.
Handle passbolt with Traefik
To make Traefik redirect incoming requests to passbolt, edit the passbolt service as follow:
Step 1. As traefik will handle the HTTPS connection, remove the ports definition for the passbolt service
Step 2. Add docker labels to make Traefik aware of the passbolt service
version: '3.7'
db:
labels:
traefik.enable: "true"
traefik.http.routers.passbolt-http.rule: "Host(`passbolt.domain.tld`)"
traefik.http.routers.passbolt-https.rule: "Host(`passbolt.domain.tld`)"
traefik:
Ensure you have correctly set your domain name (replace passbolt.domain.tld with your own in the example above).
Non-root images
If you are using non-root images, add loadbalancer.server.port label to make traefik aware of the to be used port for passbolt service:
version: '3.7'
db:
labels:
traefik.http.services.passbolt-https.loadbalancer.server.port: 8080
That’s it
Launch docker compose up -d and you should be able to reach passbolt with HTTPS and a Let’s Encrypt certificate. The renewal of the certificate will be handled automatically by Traefik daemon.
